door panel removel? how??
melmount
greensboro nc
hi guys, need to remove a door panel on an 07, do they just pull off??
shoot me some info.
thanks in advance, appreciate the time
dboyw
Lancaster, PA
If it is like the 99, there are some screws too.
Remove the trim piece front of door, covering the mirror holes. Pry up the switch cover and unplug. I think in here is where there is a screw or two. Other wise lift up on the door panel. Unplug light at bottom of door and set panel aside.
This was what I remember, could have missed a thing or two. For the front door, never did the rear doors.
There is a screw behind the door reflector. After the screws are out slide the door panel UP and it will come off the door.
