DP tuner????
Stroke
Salinas,California
Im new to this site and dont know much about the dp tuner
What is the difference between the 80hp tow setting and the 80hp econo?
Got Diesel?
just call jody tipton, the owner off dp tuner.. he'll answer all your questions.. i just got on of his chips and i love it. the number you can reach him at is 1-828-221-0076.
roosterdiesel
Earl needs B100
Amarillo,TX
Welcome to the site Stroke!
When I was running DP tuning my 80tow was a little less responsive on throttle tip in than the econo. It also smoked more. But my setup was not anywhere close to stock.
I no longer use DP Tuner. I've run TS, DI, DP and TDP.
kbud14
I will never learn
Ohio
Any reason why you switched? I dont want you to bash DP, but I am looking at a new chip and DP is one option that I have narrowed it down to.
roosterdiesel
Earl needs B100
Amarillo,TX
I still have the DP chip, just don't use it. I have an odd PCM code that needs live tuning for Jody to get the quirks out with my setup.
Why did I change? Had the opportunity to run Tony's chip and like it more. Smoother idle and seems to be stronger, no dyno numbers to prove it yet.
