*Draining the Tranny Fluid ?*
smokin joe
Smokin.....
Fox Valley, Wi
Does anyone know if there is a plug on the torque converter so I can drain it ? I want to replace the fluid that is in it with Amsoil and I was told by one of the local garages that if I remove the cover by the tranny there could possibly be a drain plug right on the tourque converter. If not.....any suggestions??
:thanks
hheynow
Señor Aceite de Soja
Northern California
:thanks
When I changed from reg ATF to Redline synthetic ATF in my tranny I had the whole system flushed.
You're not referring to the plug on your transfer case are ya?
My stock E4OD TC had a drain plug in it, I had to remove the inspection cover and bar the engine over until it came around. I think its a 1/4" plug. If you dont have one you are going to have to use the flush procedure to get the tranny fluid out of the TC.
smokin joe
Smokin.....
Fox Valley, Wi
You're not referring to the plug on your trasfer case are ya?
No, I want to get rid of the old tranny oil and replace it with Amsoil. The guy told me there is a plate behind the tranny (on the bottom) that you can take off. He said you have someone tap the key so you can see the tourque converter and there might be a plug on the converter that you can take off to drain it. He said that would save you from having to take off a hose and waste a couple of very expensive quarts of Amsoil.
smokyred
SDD Wannabe Mod #2
Wellington(home) and Lima(college) Ohio
I believe our trucks have a drain bolt on the front surface of the converter. I know my Dad's IDI has a drain, but I I don;t recall weather it was on the front face or the outside barrel part of the converter.
Pull the cover off and shine a bright flashlight up in there, and tell us if there is one. Sorry I can't help more, I'm still learning! :oops:
ON EDIT: It appears I need to type faster! :D
smokin joe
Smokin.....
Fox Valley, Wi
Thanks guys. I will give it a try when it warms up. Right now its 10-20 below with a wind chill of 30-40 below. I dont feel like doing this even in a heated garage when its this cold. PLUS we just got dumped on with 10 inches of snow. Thanks again
lifted_up
TractorMan
Drippping Springs, Texas
the TC in a E40D/4R100 if it is stock has a drain plug. Flush the system really well and especially the cooler. Check out Schaeffers 204SAT synthetic blend ATF before you buy the other.
hheynow
Northern California
I have an aftermarket TC without a drain plug which is why I had mine flushed.
dserge66
