Question Drivers door rattles
Choaner
Pittsburgh
Just as header states, when going over bumps door rattles - If I hold against it, it stops.. The rubber all seems to be in good condition and the stops do as well... Tried adjusting striker but it is not moveable.. Any thoughts.
RSG
Savoy IL
There was a "fix" for quieting the ride some time ago... I recall that you run vinyl tubing inside the hollow weather stripping all around the door. This tightens it up considerably and makes it quieter. I guess it would provide enough extra compression to reduce or eliminate your rattle? Somebody on here will recall the details...
Choaner
Pittsburgh
Great! I will try searching for that, sounds like a good idea..
Ok searched to no avail.. Any other info?
The strike does not adjust, as you now know. The pin on the door is adjustable. Loosen it and move it OUT to move the door in, and then TIGHTEN it up good.
Choaner
Pittsburgh
Thanks Guys,
I did find that article last night - thanks for the help...
DaveBen, I did move the door latch, but was only able to get about 1/16" out of it.. I will try and shim the stops first, then weather strip if no go.. Thanks again.
Thanks Guys,
don't waste the effort.. run to Lowe's and get enough of that clear vinyl tubing to go around the entire door frame... stop by NAPA on the way home and pick up a gallon of Ruglyde (dish soap gets sticky when as it dries).. just pull the weatherstrip off the door frame, and give it a colonsocopy with the clear tubing. Cut to length and re-install...
X2.
And'a Fish Tape, to pull the vinyl through.. and'a "Helper" helps.
Dogman
tampa,FL
My old F-150 had the same problem. I found in my case that the striker had a plastic tube on it and it was gone. I put a new striker on it problem fixed.
