Question Dually hubs 2004/2007
robertc68
Md
Hi,this is my first post .I hope this is the correct section for my question.
Does anyone know if the dana 80 rear hubs are interchangeable from a 99-04f350 drw verses a 2007 f350 drw? What I am trying to do is put the 05 and up wheels( 8x200 bolt pattern) on my truck which is currently 8x170 bolt pattern.For the front I am putting in a 2008 axle,so I have the correct bolt pattern there.I know they all have dana 80 rear axles,but not sure about parts interchanging .The reason I skipped over the 05-06 years is because through my research so far I have found out the inner hub bearing was bigger for those years,but in 07 they went back to the same size hub bearing that the 99-04 have,and that could be my answer to whether it will work .I appreciate any help thanks...
