Early 99 throttle problems
LKR Racing
Calhan Colorado
I have a 99 that threw a code for the IDM and I replaced it but it is still having the same problem. The problem is that after running a while if I let of the throttle it turns the check engine light on and there is no throttle but if I put it in neutral it comes right back. I replaced the throttle position sensor and had a wiring diagnostics done to check for broken wires in harness. I am at a loss. The truck does have 276,000 miles on the original automatic tranny.
Thanks in advance
that's a good one..
the throttle responds but the truck has no drive, or the throttle doesn't respond?
LKR Racing
Calhan Colorado
Could it be a sensor in the tranny or the tranny needing rebuilt. Or could the cat be plugged and when it heats it cause to much back pressure and chokes it down?
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
Your early 99 still has a "kitty"? :innocent;)
on edit: I'm wondering if it might be a EBPV thing.:dunno
Maybe something to do with the EBPSensor tube going from the rt side exhaust manifold to the sensor near the top/front of the motor by the HPOP reservoir.
A way to check for it would be unplug the wire connector for the EBPV acuator on the turbo pedestal. If the problem goes away, you've got it narrowed down.
The throttle does not respond.
If that's the case, the first thing I think I'd do is get a seal pick or similar tool and squish the terminals on the connector for the throttle pedal sensor down a smidgen and try it again.
If the problem persists, do the "wiggle test" on the harness. It may have a wire broken inside the insulation causing an intermittent open. Remember, it only takes one strand of a braided wire making contact to pass a continuity test.
