EGR Removal Help!!
megandjasonkay
I am trying to replace my EGR Valve on my 05 f-350 6.0. I got the 2 bolts out but can not figure how to get the old EGR Valve off. I am having no luck on grabing it and twisting off. Is there a trick to it or do I need a tool?
Any tips on re-installing the new one would be greatly appreciated!!
Big Channel Lock pliers should work. It is a twist and pull operation. Clean it out completely before re-installing. No tricks here.
megandjasonkay
Thanks to all for the help!I got it off. And installed a new one. Truck is back to running great. Not a drop of black smoke even on hard acceleration. THANKS AGAIN!
TIP for others - A paint can opener works perfect for a small pry bar with channel locks.
nascar_fan28
IL
cool, well when my truck is outa warranty and i need to replace it, i know, thanks
becareful you dont mar the surface on the engine side...
and be certain to replace the gasket.
an alternative "removal method"...remove the 2 bolts,
turn it about a quarter turn and run some bailing wire
thru the bolt hole "eyes" and put STRAIGHT up on the
wired/egr...itll pop right out.
