Engine died on road: Sorry Long
Sportsnutim
Sportsnutim
Belfair, WA
Well it finally is DOA. On the road; stopped running in the middle of the road. Glad my wife wasn't driving it. It has been cold here. I had the engine block heater plugged in say two hours. Started ok: warmed up maybe 5-10 minutes started driving up the road it began sputtering and running extremely rough then died. If it is the cam sensor I sure wish Ford would of let me know. I checked on the Ford site and certain Ford vehicle at certain plants are under the "voluntary recall" I put my VIN# in their data base and it is under the recall so I was in the process of going to my appt to have it checked out. Murphy's Law was with me. Not happy with Ford considering my trans blew up 6 months ago. If the truck is not completely warmed up could it be the sensor? :rant
Sounds like another CPS failure to me. Warm or Cold, makes no Dif. As you know, Ford will replace it for free. Often, they will restart.. maybe you could "Limp" it to Ford ?
Your call but.. While you're there, you might consider buying a Spare. The New & Improved CPS (Grey one) is supposed to fix the problem but I carry a spare, just in case.
It's an easy DIY fix too. :dunno
F350DRW1
Waylon Fan
N.J.
Need a little more info, like year and engine. CPS could be the culprit.
silverF250
Arnold, Mo
It is an 01 7.3. Yeah it sounds like the cps. Call the dealer up I thought I read that they were helping offset some poeples cost of having to have their's replaced. If that is the problem they may tow it for free.
Sportsnutim
Sportsnutim
Belfair, WA
Here's the info
2001 Superduty 4x4 F-250 7.3. I had the Cam Sensor replaced about a year ago. I am guessing it is the black one. I will definetely buy a back-up just in case it happens again.
Sportsnutim
Sportsnutim
Belfair, WA
Hmmmmm
I am wondering is this a recall for safety? Because if it is the Cam sensor we have been in situations where it was quite dangerous. If so, why wasn't there a letter put out to those who are covered?
Sportsnutim
Sportsnutim
Belfair, WA
Thanks for the info
After it died. I barely started it after 20 minutes ran kinda rough and limped to dealership.
;tu Glad to hear it;tu
I talked to my Dealer about notification. He said Ford is supposed to be in the process of notifying all concerned with this but :dunno
DANGEROUS ? If it failed ? I certainly agree.. :eek: :eek:
F350DRW1
Waylon Fan
N.J.
They are hitting it pretty hard. I got the CPS notice on trucks I haven't owned for years. I would have to guess IH is mailing them out for medium duties they have sold with that same propblem.
jestersv
7.3 addict
waterloo il //stl.louis
how cold has it been? sounds more like fuel gelling not cps not that a cps failure would cause the same symptom but sounds like fuel starvation.
