extra connectors on truck
sunilp
Houston, TX
I have a f250sd with KR and I got it fully loaded with nav. I noticed 2 connectors on the rear side of the truck under the bed. One on either side of the frame not connected to anything. They are white. Does anyone know what this is for? Also, noticed a white connector under the hood above the right wheel.
Nebraska
Detroit
They are most likely for the secondary fuel sending unit if you only have a single tank. Should be a 4-pin round connector if that's what it is.
TWO connectors ? what year truck ?
could be reverse sensors could
be rear mounted camera
