F250 rumble at 60mph
ProXJC
Michigan
Have been noticing a low rumble in what i believe is in the drive train or rear end. It comes around 60 mph and when turning after a stop. When towing a trailer its real noticable at turns. When coasting around 55 it does it briefly. Its driving me nuts!!! Not sure if i have rear end going out or a driveshaft that needs to be balanced. Any help would be great before i have to bring it in.
I'd start looking real close at U-joints
X2 on U-joints.. and the Carrier bearing and Slip Joint too... ?
ProXJC
Michigan
I finaly tore the driveshaft out today. The u joints are fine along with the carrier bearing. The slip yoke seemed to have a little slop, but it was minimal. Im going to have it inspected and balanced and see what happens from there... Yes it is four wheel drive
ProXJC
Michigan
I got the rumble at 60 MPH solved by having the drive shaft balanced. But it still rumbles when turning at a stop, especially when towing. I wonder if its just the over size tires.
Dieselpwrdredneck
Addicted2Diesel
paris, Ohio
are ya positive it is coming from the rear check front wheel bearings, especially the needle bearings around the axle
maybe change the lube in the rear diff?
does it chatter/vibrate as well?
3 or 4 trucks ago, I had a 4X4 that made noise when turning. It had a tight posi and it was the clutches chattering when I went around corners. I left it alone and drove it.
Dave ;tu
