Feels like a 4-barrel carb truck
silverF250
Arnold, Mo
I need a little help the truck feels like it's a 4-barrel from 45-60 mph. If I stomp on the go pedal it takes a couple of seconds and then it screams. It did it the other day with an empty trailer behind it, but didn't do it with 8500 lbs back there. Then all of a sudden it starts on the way to work today. I did get fuel at the same station last wed. and friday, with a couple of fill-ups in between. I put some cetane booster in this evening hopefully it is bad fuel.
silverF250
Arnold, Mo
Fuel filter has about 10k on it air filter is clean. Boost gauge reads about 5psi until I mash the throttle and then will climb fine. No strange noises or any smoke other than the black cloud from stomping the throttle.
check the MAP sensor tube to make sure that it is not restricted or leaking at the map sensor.
