filter replacement time
Bolt
Plainview, Texas
F350DRW1
Waylon Fan
N.J.
Anybody have any good ideas on the tranny fluid change procedure, other than let the stealership do it?
The old crack the pan and wear a gallon or two always works, but, uh... this stuff really stinks...
You should have a drain plug on bottom of pan, Kleetus. I have removed plug, drained, and then started truck and cycle thru R and D a few times, and you get alot more out because there's no drain plug on your converter. It always helps to put down some cardboard because it will be a mess. And have the parking brake on, natch. The front filter [toilet paper filter] canister can be a real PITA to get off w/out an impact gun. This fluid has a smell of its own, no doubt. Good luck and have fun! :roflmao
