first diesel
You can use a volt/ohm meter and measure from the tip of the glow plug to the ground. If it is good, you should see about one ohm. If it is open (no reading or infinity) then it is bad.
how do you check the gps.
:) Talk to us Guy ;)
How many miles are on your New To You 7.3 ?
Do you have Scanner ? Or access to one ?
Is your "SERVICE ENGINE SOON" light on (?), on the dash ?
Do you have the tools, skills and a place to work on your stuff ?
Have you used the SEARCH, DIY/Wiki feature here on SDD.COM ?
RIGHT NOW......The best thing NOT to do is: Use Ether ! It can be Very harmfull to your engine, Very Quik.
The Water In The Fuel light means.. you need to drain, and clean your fuel filter bowl, AND change the filter.
Joe :)
adam65
mchenry il.
151,000 i can hear the solenoid click when i turn key guess ill have to check gps
adam65
mchenry il.
tested gps there not all working thanks guys uv been big help. sure ill have more questions
Milly333
