Help Needed Flare install
Wiester
Alberta
I need any or all the help I can get. I am installing bushwacker cut outs hopefully this afternoon or tomorrow. Are there any tips or tricks on these? I know cut less, trim as required, measure twice cut once n all that. Anything else? I would love to see some in progress pics. I haven't been able to find one picture online people took after the cut or during the cut. I will do that for sure
smaller cut-off wheels give you a bit of an advantage making the radius you want. do not try to make the cut all at once take it off in small pieces use relief cuts to get in there unless you're cutting with plazma.
Wiester
Alberta
Noted. Still gettin the courage built up to do it. Just by reading the instructions and lookin at the truck, it seems I have to cut the truck a bit too right? Not just a fender trim but the bottom edge of the cab and also some inner fender metal that's body mounted and not fender right?
