Flashing OD light, no AC, no Turn signals AHHH
hammer450r
NJ
I checked every fuse on the truck, #24 fuse is for AC clutch, turn signals but the fuse is fine and there is power to the fuse. Any ideas where to go to next? thanks
Tbar
SDD STAFF/Moderator
How old are your batteries..............
Tbar
hammer450r
NJ
Well i bought the truck a year ago, and he said they were fairly new. Can i check them with a multimeter?
I've been having trouble with the vacuum motor losing power and my AC going to Defrost mode. Now that is working somehow, then all this is what i got in return.
You had better look at new batteries. Diesels are hard on batteries and your problems seem to be all electrical. These trucks show weird electrical problems when the batteries go bad. The volt meter won't show a lot. You NEED to get your batteries LOAD Tested. Most bigger Auto Stores will have a load tester that they can test your truck.
hammer450r
NJ
Thanks guys ill check it today, ABS light is on too.
hammer450r
NJ
Well the batteries are good, the one needed alittle charge but was good.
I cleaned the terminals and reinstalled and it still is doing the same thing
hammer450r
NJ
Of course i didnt get the reading it just said it was good
hammer450r
NJ
Now i did pull a fuse while the truck was running right before this happened, dont know if it has anything to do with it.
