flushed sail panel tweeter mounts, components install, dailup run and hide
paulkeith
Da A
alright, here's the system specs:
current:
sony headunit, autotek 900.4 stealth series amp, ED 11ov.2 sub in a custom box.
in progress:
CDT EF-61 comps in the fronts, peel n' seal roofing material as sound deadening on the back cab wall. this is gonna be it for the truck stereo.
I used PVC pipe that fit the size of my tweeter cups, and cut it to teh angle i wanted.
so....here's a pic by pic of the tweet mounts.:
take the hole saw to them for the PVC:
basic shape:
both glued on:
apply the semi-rigid liquid plastic, called Duramix 4040 ($36 shipped from levinauotparts.com)
here i got a little lazy with the pic taking. before this next pic, i chucked a sanding drum into my drill press and spent about 1 hour on each mount making the basic shape i wanted. after that came a coat of bondo, much sanding, another coat of bondo....to this pic:
ready for paint:
I painted them with DupliColor truck bed coating, available from wallyworld:
paulkeith
Da A
mounted up in the truck:
next up was the crossovers and running new wire to the doors:
i'm still waiting on my speaker adapter plates to come in before I can finish it up. I also want to put a little sound deadening on the back wall, so that'll come tomorrow. look for more pics tomorrow night.
also, unrelated....
you think you've got humidity? this is the chuck of my drill press, indoors:
enjoy. if you have any q's, let me know.
Nice job Paul. I noticed while test driving a 2008 F450 a few weeks ago, that they have factory mounted tweets in the mirror bolt covers too.
gotta say both you guys did a better job than the factory
has done on the 2008 sail panels !
Im inspired ;)
paulkeith
Da A
MUCH better use of PVC pipe than the last time I saw you build something out of PVC!!!! :tounge
Looks good man!
i hate you...haha. we need some flipoff2's around here
Nice job. Here's a pic of my custom tweeters, I sanded a little more to a smoother surface and dry sprayed the last coat to match the factory texture:
Bart
damn, i like yours better. I had mine sanded really well, but decided to go with the really textured paint. I'm kind of regretting it now, its a little bit too much texture i think. I like your tweeter location better too. I went the direction I did because I was worried about mount depth, and then i realized that tweeters are like 1/2" deep. oh well.
4wdbeast
Thibodaux, Louisiana
i hate you...haha
Don't be too harsh on yourself and don't hate me too much :)
If you check my photo series, you will see that I messed up my first set of sail panels. The direction of the tweeters is cross aimed at the head of passenger/driver.
Bart
