FM Direct Adapter
J.Rol
Pemberton,Mn
I have a 2009 F-350 and bought a FM direct adapter for my sirius satelite radio. When I went to install it the connections to the antenna were not the same as the direct adapter. I haven't researched it much but figured this would probablby be a good place to start. Just wondering if they make an adapter to make this work with my stock radio or if they make direct adaptors just for ford trucks.
Thanks.
IHC Power
STOCK STROKE
Walpole Mass
Using the stock radio it should fit. But if not the antenna plug on the adapter is typically straight? I got one on my Pioneer with Sirius. They might have changed the plugs from 2001 to 2009. Try Radio Shack they have assorted antenna plugs that don't require special crimpers, there screw type. Good luck.
