Ford F350 running on vegetable oil
KansasDiesel
fly'n low on WVO
Kansas City area
Well the forum changed here but thought I would add that my truck is now converted to run on vegetable oil suppliment.
Those of you from TDS may have heard of Fordnut 74, I have installed a system like his, installed an electric diesel system and removed the existing mechanical pump/filter/regulator.
I am also working on making Bio-diesel and trying to start a COOP in the KC area for the Bio-diesel and WVO. If in the KC area PM me if interested.
Ed
KansasDiesel
fly'n low on WVO
Kansas City area
95_stroker said:
Sweet Ed! How do you like your system so far?
It is running great, :thumbs going to take it to a Dyno this week and see if the performance is different while running vegetable oil. :thumbs
I have just a issue of getting the oil to heat up a little faster, it took me 6 miles before I could switch over to oil and that was pushing it. I want to get it to switch over faster. As it gets cold here It will take longer to heat up as well.
No problems with running on it. This set up has been the easyist that I have seen. Much easier then my Mercedes.
gquad41
