fpr mod
big bear
west plains, mo.
just did the mod and i was wondering if anybody could tell me what to expect from this mod. better reponse, better pick up, better milage maybe, eng. run quieter maybe???? any info would be helpful. thanks to all!!!:dunno
big bear,
I moved your post to a new thread of it's own. It was not related to the 15w-40 thread and will get you a better response here.
early 99 stroker
White Mt's NH
better reponse, better pick up, eng. runs quiter is about it..if its set to high..(70PSI or higher) the truck may run ruff...65 PSI is recomended..
ward cleaver
Californication
I have a California truck so it's already factory done.
(I didn't know that until after I got a gauge and did some research.):doh:
kiarasue
The RamSmoker
Enumclaw, WA
The best program I came up with was the IT diesel end cap with the reg. gutted and plumb a adj. regulator to do the job. 105psi is the max pressure for all around performance.
JRJ04
Houston, TX
105psi is the majack no. for all around performance.:tounge
105??? How have you not seriously damaged anything? I have never heard of running your fuel psi above 70. Anything above that and you start to run into issues. Do you have an aftermarket fuel system?
Someone else chime in here, but I think 105 psi is WAYY high.
02stroker
Gratz, Pennsylvania
I just installed the Dieselsite fuel pressure regulator. Set it to 65 psi, as reccommedned. Bob told me that more than 70 will yield no further gains and will infact cause harder starting. I currently am running at 60 psi because the truck was starting hard when warm. I would think that 105 psi would just cause alot of fuel leaks, among other problems.
