FPR Shim
MBRPCrazyford
Eat Some Smoke
Harrisburg, PA
Is it ok to shim the stock fuel sytem? Does it have enough power to pump that fuel? Also, if you ca, how do you turn up the air-fuel mix on these trucks?
A diesel engine runs on a constant air volumn per rpm; that is you get the same amount of air per revolution and it does not change like on a gas engine. What you do is increase the fuel per revolution with a chip, or programmer. With mechanical fuel injection you would turn up the injector pump and that does the same thing. These trucks are NOT mechanical injected. You will need a chip or a tuner.
Yes, the FPR is part of the fuel filter assy, you are looking to take out the brass bolt on the drivers side. Careful as there is a spring in there.
