Chopper Boy
sdd Junior Member
I got up the next day from the oil leak around the dip stick where it goes into the pan,started the truck & it idoled rough (has nothing to do with oil leak) so I thought maybe it because it was cold it was 12F but it was pluged in, so I let it warm up I went inside. about 5to 10 mins later I hear the ex die so I go out the ex tries to start but it is nocking but not oil but like an injector nock. I had plenty of oil psi so I thought its not oil. So I called the tow truck they took it to ford they looked at it & said it was #1& 2 injector this is a stock ex with 188,000 they wanted 1800 to fix it. I asked if they had checked fuel psi they said no. They check fuel psi it was 10 psi (lift pump was bad so they checked the tank They found that the fuel screen was stoped up & that burnt up the lift pump witch mad the injectors 1& 2 go bad. At this point they wanted 2500.00 to fix it only 2 injectors,lift pup & screen.
S0..... I order stage II 32 L per min Dynomite diesel injectors all eight, a dp turner 5 setting 1. stock 2. 60 hp tow 3. 100 hp daily driver 4. 120 performance 5. extream (tossed the supper chip for sale for someone)new lift pump & new fuel screen, ats housing , new compressor wheel, fuel Gauge,hpx hose,203 thermo,al thermo housing!!!!
HOLLY COW !!!!!!!after $6000.00 later this thing bettter run GOOD!
so what do you guys think did I go the right way on this?
P.S. Ill get to the oil leak next week (black rtv I ran out of money)
Chopper Boy
Chopper Boy
