Front end bump stops for Excursion
ForumBlue
CDXX
Southern California
Where can I find replacements for the front end Bump Stops for a 02, 7.3, 4WD, Excursion. Ford wants 45 bucks each for these hunks of rubber and I was wondering if there was something else out there for a reasonable price. I'm not sure if Bump Stop is the actual name but the part number on the part itself is YC35 3020 AC
EDIT: I just noticed that there is a bolt hole between the 2 holes where the OEMs came off. Can I use the ones like are on the rear with the one bolt that goes up through the middle of the stop itself or is there a reason why the fronts need to have the 2 hole mounts ?
picture.php
Thanks.
Sorry for the late reply,the replacement(or revised/updated) Ford front bumpstop part number is 2C7Z3020AA on Powerstrokeshop.com website they have them listed for $22 and change each.
The bumpstop on the rear leaf is a single bolt and won't work on the fronts unfortunately.
I removed the rear bumpstops during the installation of the Radius Rods.
