Front Grill
Smoky
Mississippi State
What is the newest grill that I can just take only the grill off my 2004 and bolt right on. I really like the 2007 model grill. Will it bolt right in place of the 2004 grill?
Racinghcr
Racinghcr
Greensburg,Indiana
2004 Ford Grille
Smoky: Not sure ,but I think the 05 & 06 Grille would fit and look awesome in your Truck ! If your old Grille is not scratched or damaged.I'd like to buy it for my 2001 PSD F-350 if it will fit. Mine got hit by a piece of debris from a semi while pulling our Fifth wheel Rv down to Fla. Good Luck and thanks Harry (cell 812-614-9262)
6.0PSD777
Mass
Basically just an 04 and down - If you want to use an 05-07 grille you have to change your bumper too because it comes down lower than the older style. Not sure if the headlight mounting panel is the same.
BIG DUTY
F-250 Care Taker
Traverse City, MI
The 05-07 grill will work with modification. Using your stock bumper will require you to trim some material from the bottom of the 05 grill. Or you can change the bumper as well as the headlights thats what i did on my 2000.
Smoky
Mississippi State
Prefer not to trim but has anyone done this upgrade just changing the grill only? If so please tell me your story and post pictures.
