fuel drip
huey52
Huey
Apalachin New York
I have a 2000 F350SD 7.3L and I have diesel fuel dripping from a small tube on the passenger side of the engine. I am not able to trace the tube back to the it's source. Anyone know the cause of the drip and the remedy? Truck has 108K miles and the drip is constant when idling. Thanks for the help
TurboTy
Toms River, NJ
sounds like the orings on your fuel filter housing drain valve, common problem, i'm sure you can find threads on here all about it, the tube your talkin about sounds like the drain tube for the housing, orings are cheap, and its relatively simple to do. Hope this helps
