FUEL LEAK < fuel lines to head >
stealth_600rr
stealth_stroker
Tucson AZ
Has anybody had a fuel leak at the fuel line connector thats right before the fuel line enters the head ? I had a fuel leak to begin with and found it to be the fuel pump, a few months later guess what ? fuel leak again, this time it was the vacuum sensor on the side of the fuel bowl, now i'm leaking again !!!!!! but the valley is dry except for the very rear right by this fuel line, but ive never heard of leaks coming from here..........by the way hello I'm new and i'm a diesel addict (i've heard accepting it is the first step). truck is a 97 f250 supercab:thanks
Hi and welcome stealth. You will get an answer soon by someone else more qualified in the '97 trucks.
Dave :)
roosterdiesel
Earl needs B100
Amarillo,TX
Welcome to SDD! :sweet
There are o-rings at that fitting. It slided over the steel line, steel line goes into the fitting in the head, collar slides over the o-ring and tightens to the fitting in the head.
It usually leaks at the point, I've never heard of one leaking from where the fitting screws into the cylinder head, that's just 1/8th NPT.
Are you running ULSD? It could be the cause to the old o-rings starting to leak. We've had alot of injection pumps at work come in for leaks since ULSD was introduced here.
stealth_600rr
stealth_stroker
Tucson AZ
thanks i bealive rooster got it, i'm going to ford tomorrow, to order the orings, that was my main concern, i wanted to know what i was getting into, i'll post results with pics, thanks again
rickh
Biodiesel Rules!
Bellevue Nerbaska
The fuel lines from the pressure regulator to each head?
Richard, those are the return lines, I think he is refering to the steel lines going into the back of the head. B100 finally ate my return lines and I have custom made B100 compat coming. I need to change the same orings he taking about on the feed side while I got it tore apart as well as the orings on the side of the bowl.
Fuel leaks SUCK!
Rick H...
stealth_600rr
stealth_stroker
Tucson AZ
yes, found out that in fact its the oring at the check valves (theres a check in the connector) in the return lines, the orings were 7 bucks a piece at ford.
