Fuel leak when cold
Kodadd
Knoxville, Tn
I noticed the smell of diesel the other day and could not find the source. So I drove this morning and after moving the truck there was a puddle of diesel fuel.
After short inspection I noticed a puddle in the intake manifold area.
This must be an o ring issue because when it warms up it stops.
1999 7.3
I did a search on fuel leaks and nothing came up is there a common problem area for fuel leaks?
Thanks you guys year to date have saved me over 200 bucks in maintenance.
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
Could be the "O" rings for the yellow drain valve handle on the backside of the fuel filter bowl. Very common item, pretty easy to fix.:sweet
Kodadd
Knoxville, Tn
Yep looks to be that napa does not carry the orings
thanks you guys are the best.
Ford wanted 40 bucks I am being cheep this year I ordered them from dieselorings.com 6 bucks 1.80 shipping its not my daily driver so I can wait a few days.
Again thanks again.
melmount
greensboro nc
The fuel heater has 2 orings too. That can leak. Not as likely as the drain valve, but can leak.
jaysee
cincinnati/ohio/us
I found a diesel stain recently. Looked like it was dripping from a small tube near the front. First time I've seen this. And it happened the same morning I had a dead batt.
Small tube near the front ?
The Fuel Filter canister Fuel/water Drain valve O ring(s) are shot.
Not related to the Batts. How old are the battery's ??
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
That sounds like the drain tube for the fuel filter drain. I put a piece of hose on it to extend the drain tube down lower. Makes it easier to see for one and makes it easier to catch any fuel into a bucket when I open the valve without running all over the front differential.
jaysee
cincinnati/ohio/us
Tail Gunner: Is this normal ?
Big Joe: The battery was four yrs old and replaced. I just mentioned it because that's what made me look around & notice stain.
Thanks again!
