Fuel leak
twt
Glasgow ,Ky
I have fuel leaking out of the drain pipe,will the new 0 rings stop this leak or do I need to spend $65 at Ford? I have the drain valve off now. :thanks
F-450 HOTSHOT
I had the same problem on my truck. I just replaced the o rings on the drain valve and I havent had any problems since then. Ford wanted like 35 dollars for the kit. I got the o rings from ace 50 cents each. 1 dollar sounds better than 35 dollars to me. Took me about an hour to fix it not hard at all.
Hey F-450 HOTSHOT don't use all caps, it is considered shouting and it is very hard on the eyes to read.
