fuel psi....
atk
Moderator
simcoe, ontario, canada
thinking about adding a fuel psi guage when i do rest of my guages...so i was
wondering what should be the norm psi numbers...i did read somewhere that they should be around 100 psi, but i may be wrong....
also where would be the best spot to take the psi reading from?
thanks....
I have been told around 75 or so is the stock psi, but I am not completely sure either Alex.
I think mine is set at 78psi with the reg. return fuel system.
atk
Moderator
thanks...i knew you had a guage....i may just get the same system as you, when i get my SCT....:sly ....:D
Flopster843
Charleston, SC
Mine stock usually runs about 55 psi. I've seen it drop to almost 40 on a hard pull though. I change filters every other oil change and it never gets any higher.
