welcome to the place to be
White Buffalo.
i ran the external regulated fuel pressure set up inspired by Hutch, for 50k plus miles, i probably had more miles on this mod than anyone hereat the time i removed it.
i played with FP from 40-80 psi
my 02 liked 65-70
idled quieter and with less shakey shakey, felt perkier, better off idle snap, would only cackle or ding ping at fuel levels below 1/4 tank, i never harpooned the tank, mpg was maybe 1 mpg gain if that. I did however change fuel filters more often for piece of mind, becuase a ton more fule gets refiltered with it modded
i had zero fuel related failures from this mod, and it worked so good that when we got the boss, rooster and i arranged for it to go on his truck.
would i do it again? YES
if your handy you can build your own set up, or you can get one from a vendor,
either way its an easy afternoon of fun and the end result is worth the time spent under the hood.
i ran braided SS line with aeroquip fittings, A. for looks and B for longevity.
i have been toying with putting a simliar set up on the 6.0 now
the mod bug is biting me again
