gear ratios
jopes
Wyoming
gear ratios
millage
blah blah blah
towing about 8500 lbs on the trailer side of things and typically end up having 500-2500 lbs in the bed of the truck depending on the camping trip. currently I got 373's and stock tires.
Was wondering what people with 4.10s are getting loaded up and unloaded for millage to see if it is really worth it.
Right now I have been getting 10-12 towing, and 17-18 unloaded.
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
jopes said:
towing about 8500 lbs on the trailer side of things and typically end up having 500-2500 lbs in the bed of the truck...been getting 10-12 towing, and 17-18 unloaded.
I'd stick with what you have, the towing mileage sounds about right for your load. I used to tow a 8K trailer with a 100gal aux fuel tank in the bed (approx 800lbs when full) and would typically would see 10.5 to 11 @ 65 - 70 on the interstate.
Instead of spending money on changing gears, I'd call DP-Tuner and get a flip chip with some of his towing and economy tunes along with one or two yee-ha tunes for fun. :D
I'd also like to suggest a 4" exhaust system. While a muffler delete helps with a factory configured truck, it'll show its limitations when you start doing mods.
jopes
Wyoming
I just have not gotten around to the exhaust, once I get that I was going to get a wildman chip.
