Good spot for water temp sending unit (other than pump)
ChrisMartinTX
97 F-250
Bryan, TX
got a water temp gauge and was wondering if anyone knew a good spot pther than the two on the pump to put the sending unit in. i though i saw something about the super duty guys having some plug in the head or something. no big deal just like keeping wires away from moving parts.
well you can put it in the hose feeding the heater.... The port in the head I think there is a port on the driver's head that is in a similar location to where the heater hose leaves the passenger's head and you could put it in there.
Renegade
HillBilly
Greenup,Ky
I need to find a good spot also as my autometer guage has a huge sending unit for it for some odd reason.
I'd really like to find something near the rear of the engine as far away from the tstat as possible.
I'm open to any suggestions also :D
ChrisMartinTX
97 F-250
Bryan, TX
well i ended up putting mine in the pump... figured this would be the easiest spot to service if i got a leak. i removed the plug on top and had to get an adapter. the sending unit was 1/8 npt and it came with a 1/2 and 3/8s adapters... go figure.
what gauges do you have renegade?
Renegade
HillBilly
Greenup,Ky
Do you mean brand or type?
All are Autometer Z series guages & they are for boost,tranny temp,pyro,oil press & coolant temp - I have room for 1 more on the center pod above the rear view mirror that I never decided on what to put.
I thought maybe a pre & post intercooler boost guage or maybe an oil temp guage.
ChrisMartinTX
97 F-250
Bryan, TX
thats cool... i was wondering what type just cause you size issue. yea i kinda wouldn't mind an oil temp. what i'd really like is for autometer to make an oil pressure and oil temp 2 gauge console in the 1.5" autogage series. maybe even in one of the 3 gauge ones just need something other than the water temp in it.
how good is your fit with the overhead pod? is it the super duty one? i ordered one but it just didn't fit right in my truck kinda left a gap... prolly could have dremeled some stuff down on it but went ahead and used the pillar.
If you have a coolant filter (?) you could use one of the un-used in-let ports on the filter head :dunno
