Gplug and Wiring Harness?
Got Diesel
Engineering College Boy
Missouri
Ok here goes, asking this for a buddy of mine. The truck is a 94.5 PSD. He's replacing the glow plugs, and the outside valve cover harness is burnt. The glowplug leads that is. However it also burnt the Engine Wiring harness that plugs into the valve cover harness. When I say burnt I mean just the glow plug leads. Does he need a new engine wiring harness? Or is there something else. Thanks, sorry if confusing tried my best to keep it simple.
Patrick Feeley
Tehachapi, CA
For the connections at the valve covers, you have the external harness and its 4 connectors, the valve cover gaskets with their sets of feed-through pins molded into them, and the 4 undervalvecover harnesses. Usually if the UVC harness(es) are burned, one just replaces it(them) as a unit(s). For the external harness connections, the connector shells and pins can be replaced without having to replace the entire harness. In either case (UVC or external), the valve cover gasket needs to be replaced as the mating feed-through pins will be torched as well. If the gasket is not replaced, you will risk torching the new stuff due to high resistance connections. Parts:
Under Valve Cover Harness (94-97)
(Ford) F4TZ-9D930-K
(International) 1815923C92
Valve Cover External Harness Repair Kits (contains 4 hard shells w/seals, w/o pins)
(Ford) F7TZ-14489-BA (94-96) w/o pins
(Ford) F7TZ-14489-AA (97) w/o pins
(International) 1830829C91 w/o pins
Female Pins, no wire lead (International) 1661875C1
Female Pins, with 6” wire lead (International) 2501055C1
Individual Wire/Pin seals (International) 1661872C1
Valve Cover Gasket (94-97)
(Ford) F4TZ-6584-A
(International) 1818350C2
Cheers!
Got Diesel
Missouri
Cool thanks, He is replaacing the UVC harness, Just wasnt' sure about the Engine harness conectors. But I will tell him he can replace the pins. Thanks
