Question Gpr
IDSTROKER
Blackfoot ID
Blackfoot ID
Hello
It been a long time but just have been really busy. But I do have a question on my truck. outside air temp was 13 degrees not plugged in turn key on glow plugs cycled just like normal
truck fired right up but 10 seconds later glow plugs shut off they did not cycle for the 90 seconds. What do you think problem lye's.
Thanks Bill
79jasper
El Paso, TX
There is no problem.
How do you know they shut off?
Sent from my *******-SM-G890A using Tapatalk
IDSTROKER
Blackfoot ID
Blackfoot ID
When they cycle my voltage is 12.8 and when they shut off my voltage is 14.7
Sent from my SM-G900V using Tapatalk
sure it wasn't the PCM commanding the alternator to full-field?
Mine take 2 minutes before it flares the dash lights..
Don't the '02 & '03 use a glow plug controller to run the GPR?
IDSTROKER
Blackfoot ID
Blackfoot ID
Well as far as the glow plug controller I'm not sure but I do know that I have the GPR.
my dash and interior lights are always dim till the GPR shuts off and that's what was weird about last night it started lights are dim 10 seconds later light are bright.
