Harley Davidson Headlights
trouble
Cincinnati OH
Has anyone added the newer harley headlights to there 99-04 superduty? I've read on ebay adds that the lights are deeper and require the back to be cut out. What exactly needs cut? I can't imagine that the inner fender support needs cut, right? Someone tell me what they had to do to get these things to fit before I go and purchase them.
police stroker
Dallas, Texas
Got mine off ebay also had to use a cutting wheel like a dremel to cut out the stock headlight buckets in the fiberglass core support. This is ok to do just make small cuts/remove small sections at a time til the light slides in with ease. Then get four speed clips to put in the two top holes in the core support should already be there from the factory to secure the top mounts of the new lamps. As for the bottom it uses the two factory screws on each side. Ill try to see if I have any pics.
jarrburg
