headlight knob (not an "engine, drivetrain, & chassis quest)
Tx_Atty
Master Baiter
Fishin'
Has anyone devised any improvement to our headlight knob? After almost 10 years my knob has apparently worn, or else the post, and virtually every time I pull on the lights the knob comes off in my hand. It is VERY annoying. Since it must be removed to remove the dash I can't superglue it. Any suggestions?
-popcorn
patrickc
Ontario, Canada
Inside the knob there is a little clip if you remove the clip from the knob you can bend the clip so it holds the knob on the switch better.
Tx_Atty
Master Baiter
Fishin'
cool, thanks. I'll give that a try this evening when I pull it off again at go-home time!
psdan000
Amelia Ohio
you could do what we did on one of my dads old work trucks and just snap a pair of vice grips on her! other than that if bending it back doesnt work i think you can get a new knob at the dealer. maybe try looking in a junkyard too.
A new switch only cost about 10 to $12.00 at any parts store and it would have the new clip on it. I got one once that was about $18.00 and it had the knob with it. My old 1984 was ruff on headlight switches.
Tx_Atty
Master Baiter
Fishin'
well I bent it a little yesterday on the way home and it held ok when I turned on my lights. We'll see if it holds. I may have to go the new knob route anyway. I noticed the plastic cover is cracked along the area where it goes over the post. That might be part of the problem.
Thanks guys.
dserge66
