Headlight Replacement........
check the lamps for operation,
and the last thing you always do before closing the hood is check the oil level
take a close look at my dipstick and you'll see why..
Tbar
SDD STAFF/Moderator
JL.........you are da man!!!
Thanks !!!
Tbar
Tbar
SDD STAFF/Moderator
Hummmm..............do you think I should do the other one??? :D
Tbar
oh you're replacing the lenses...
no..
I carry a kit made by Everwear that restores the laminate coating..
$50. per side...
the only thing additional you have to do to change the pod is back the adjuster screw all the way out..
It's supposed to pop off the stud, but I've never seen one do it and not break..
make sure you count the number of turns so you can get it back to the same spot you started...
Kenbo11
