Heater valve?
MUDWHISTLE
Diesel Lover
oregon
Hey everybody.
I was helping a family member today removing his exhaust from his 06 cclb and when I was undoing the downpipe from the turbo I noticed the hot water valve was leaking, I may have bumped this but if I did it sure wasn't very hard. it was coming out of the stem where the arm screws onto the top of it. I wiggled it around and it would leaks a little with the residual pressure in the cooling system. It stopped when the pressure was realeased. is there a way to tightened this up or will it need to be replaced? if replaced how much? and where is the best place to get one?
Also does a new diamond eye exhaust come with a two piece down pipe? and can the old down pipe come out with out cutting it or removing the trans crossmember? thanks for any helps guys!. Lee
MUDWHISTLE
Diesel Lover
oregon
Ok figured out the exhaust question but need help with the hot water valve ? on the right valve cover still.
Zmann ARGH
AZ
that shuts the hot water off to the core when using the AC ,, the part is 40ish
edit I found a web site,, sent you a pm
Skram
