help comfuser issues
bbressler
Happy, TX
What's in your proxy settings?
Tools, internet options
connections tab
LAN settings
Is anything checked? If so, try with all items cleared..
Wood County Tx
connections tab
LAN settings
tried it with all blocks un checked
no joy although it took longer to get a PAGE not found message
then i checked auto detec settings...same respnse
its getting me bugged.
it will ping out but not connect..
bbressler
Happy, TX
Sounds like it may be a firewall/content filter that may be blocking...like you say, since you can ping out, you are definitely getting out to the net for that traffic, so it's got to be something else blocking it.
Do any sites work? (I know this is the only one that counts...)
Sorry I'm not more help.
Wood County Tx
nope i even typed in my bank site and it comes back not found :(
thanks i will keep on purging through .
Maxtor
Redding
First try repairing IE by:
Click Start and then Control Panel (or Settings and then Control Panel)
Double click on Add-Remove Programs
Highlight Internet Explorer
Click Change-Remove tab
Select Repair Internet Explorer
Then click OK to confirm this
Once this has been completed restart your computer and then test your connection to see if you can now view webpages
If this does not work, it could be TCP/IP corruption.
To refresh tcp/ip with XP do this:
click on Start then Run and then typing command and then click OK. In the black command prompt type in netsh int ip reset resetlog.txt and then press ENTER on your keyboard. It should return back to a blank line into which you can type exit to close the command prompt.
If you still can not load web pages,
Try re-installing Enternet Explorer. Using Ping shows that you have established a connection. Another handy tool is wsping.
A way to check if the firewall is causing you the problem is to see if Outlook "email" is working properly.
Good luck.
Wood County Tx
thanks all
after 6hrs of battling the electrons i finally found the culprit
norton had expired and was locking me out of the internet, although it kept telling me to go to thier site to update, it wouldnt let me, so its deleting as we type
now to fix why this screen is loading funny scripts and odd text styles ?
oh and only 69 windows updates left to upload....:(
do i win a prize ??? I think i was the one that mentioned this as
a possible problem source.
and fwiw i feel your pain...ive busted TWO laptops in the last month
and my tower/server @ home has had TWO "c" drive failures w/in
about 3 weeks...im SICK to death of loading OS's.
Tbar
SDD STAFF/Moderator
I dispise Norton...............will never use it again. -mad
Tbar
