help, hard or no start after sitting
godofdew11
where is the bus today?
So ive been having trouble with my 2003, if i let it sit over night and start it the next morning its fine, but if i wake up late and it sits for 12 hours or so its very hard to start, i havent been home in a while and it has sat longer and my dad could NOT get it to start at all, has one of the new CPSs in it. once it starts fairly rough idle lots of blue smoke, if i hold it cranking some whitish smoke comes out. havent trying actually pulling chip but does the same thing in stock position. not sure where else to start.. temperature doesnt seem to have any bearing.
Don
roosterdiesel
Earl needs B100
Amarillo,TX
The white smoke on cranking means you are getting fuel but it's not burning. First jump the posts on the GPR to bypass the relay. If it still won't fire you should prolly have the batteries load tested. If all those check out you will want to ohm out your GP's to.
