Help help help something wrong with my new diesel 2000 F-350
Hawkeye Deadshot
Columbia, South Carolina
I have a 2000 7.3 L Powerstroke turbo four wheel drive crew cab and something is wrong this morning when I started it any help appreciated
Something bad happened, airbag, abs lights on, speed not working, and overdrive light flashing
I did have water in the passenger side air vent it's been raining all day yesterday I'm not sure where the water got in the vent at
Ruining ok though
01yellerCobra
Cali
Is that the generation with the GEM under the windshield? It sounds like something got wet that shouldn't be wet.
ABS, speedo & overdrive flashing might come down to a problem with the sensor in the pumpkin. I've also seen a lot of wires break inside the insulation at the connector (I think my truck has this malady right now).
But if it did NOT do it before it rained, I agree with the post above this one. Likely the windshield leaks and water has gotten in to the GEM module.
Hippy
Atlantic Pa.
That is a common issue with all of the Ford Tks. Windshield leaking . Have the windshield resealed even if you can't see where it is coming in . It only gets worst. I have had the lights, radio and heater motor start running in the middle of the night.
TwinTop
Kaysville, UT
If you've got running lights on the top of your cab check them also as a source of water getting on the GEM module.
predatorproblems
Central Texas
Mine did the same thing. Seal the windshield and dry it out. You should be good to go.
John Capawana
Georgia
I found water on my “catch all” floor mats.
Fan and radio were running without the key on. Etc., etc. I replaced the batteries, circuit breaker panel entirely and the ECM (new from Ford) I insert the key and NOTHING!
Not a beep or buzz no attempt to crank.
Any ideas out there?
Triton
Houston, Texas U.S.A.
I had the lights on my truck come on during a rain storm, I posted on this website what happen and one guy said windshield leak and sure enough he was right. The passenger side of the window was leaking and ran down a channel dumped the water on the the ECM. Who would have thought?
