HELP! Need wiring info for clearance lights
TexasExcursion
GOD Bless America!
West Point, NY
Hey all, anyone know which wire in the headlight switch pack of wires is for the running lights? I have my new clearance lamps installed, just need to know which wire to tap into. I applied power to the lights to verify they're operational, but now need to wire them permanently.
Thanks!
King0581
Monroe, VA
On my '03 with the 7.3 it was a brown wire in the head light switch bundle that controlled the park lights. Test light always works well to verify it.
keanoknick
Big Stroker
Cowtown TEXAS
In my 05, there is a wiring harness just for this purpose, which was on the passenger side, on the sidewall behind a plastic panel, down under the glovebox, just to the right of the floormat. That is where the ford factory harness for the clearance lights plugs in, I just tapped into that, as I didn't want to mess with the wires at the headlight switch.
jarrburg
