Hey guys, I could use a little help here, I already posted this over at fordexcursions.com but figured I'd try here. I have a 2000 Ford Excursion PSD, its got 124,000 , I'm the 2nd owner, its got a 60hp chip in it, otherwise its stock and in the last month its starting to had problems with not starting. It will run all day then I pull up my driveway which is rather steep and shut it off and for the 4th time since mid Aug it will not start. 1st time they replaced the CPS, a week later it did the same thing, then it was the exhaust backpressure sensor and they replaced the oil pressure regulater(I think thats what it was called). 2 weeks go by then it was the injector pressure sensor. Today it ran fine all day, went to leave this evening and nothing. Every time it will crank and crank but to no avail, it will start with ether but if I shut it off it will not start by itself again, it needs the ether. I find it really wierd that it always fails in my driveway(lucky?) which is like I said, rather steep(front end facing uphill), if I drift down to the flat road it makes no difference in starting. I changed the fuel filter on Mon, it gets changed every 2 oil changes, I'm sure this little fact is irelivant though. To be honest, I'm getting fed up with this truck, I've had it since Mar. I can accept something like the CPS going cause its one of those "known" things that go wrong but this is just week after week of problems. It always runs fine otherwise. I think I've covered everything, any help would be really great, I"m just wondering if this is normal to have sensor after sensor go out like this, sorry this is so long, thaks in advance--Kyle
Do you ever notice white smoke on startup? What's your oil level?
