Help with factory fog lights
DM761
Chicago, IL.
Can someone help me out here? 2009 f250 S/D 6.4ps crew cab with factory fog lights. Want to keep fogs on with high-beams on. Was any easy fix on my Tacoma, need relay location and or wiring diagram from someone who knows the best way to do this on this specific vehicle. Thank you to any and all replys in advance....
Mac Land
Pasadena /CA
Same questioin but for the 08
I think its exactly the same system. I was going to run a line to my upfitter switch and try to find some way to add a breaker or regualtor so they won't get double power if the upfitter switch should be turned on while the fog lams were already on. I was going to add 2 extra fog lamps as well an put them on eather side of the license plates. Not sure if this sounds like it could help you but its an idea.
AK Rover
Kenai, Alaska
Google Brite Box. It's a plug in conversion to keep the fog lights on with the high beams.
