HELP
bonestroker
stroke it if you got it
In the field
I need some help my truck is in roosevelt utah brooke down. Is what happen is it coughed about 4 times then died, it will crank BUTT it will not start. I changed out the cps with no luck. It acts like she isn't getting any fuel, and I have to head to col on friday :cussing:
stroker21
Midland, TX
Mine had cps symtoms once and it ended up being one of the relays that deals with the cps. I forget the one.
Brad B
Winnie, TX
I saw a post on here about a #22 maxi fuse being blown and showing those symptoms.
Vinni
I didn't do it
Helotes, TX
If you think it is not getting fuel - drain the bowl with the handle - take off the lid - pull the filter and turn on the key. Additionally, you should be able to hear the pump on the frame rail.
bonestroker
In the field
Sorry i didn't get back quicker, It ended up being the icm what a pain in the arss that was .But thanks for all you help :thanks
