Question Help!
phillipdellis8
US
Truck while driving down the hwy started running rough similar to running out of fuel...... Positive both tanks have fuel..stopped briefly and @idle truck is really idling terrible when resuming down the hwy just not up to par after a few minutes I stopped again and again @ idle truck really started running rough then died and will not start!
Sent from my moto e5 cruise using Tapatalk
tabdiesel
Flower Mound, Texas
Do you have around a 1/4 tank of fuel? Could be your "shower head" has fallen off of your fuel pump pick up. I'm in the process of that right now, can't let it get below 1/4 tank or she'll start sucking air.
john mathis
ramsey,il
My 7.3 did the exact same thing a few years ago. I had a heat probe for an Edge box in one manifold and immediately started losing temp on that side. The wiring harness under the valve cover for that side that goes to the injectors had a connection that came apart. Very common problem and they run like $#:+ on 4 cylinders.
Shaggy
Administrator
Staff member
Arizona
Get it figured out?
