HELP!!
jguzman75 said:
What is "QD" and is this the fuel pump under the drivers side frame rail?
QD= Quick Dis-connect. The QD fitting prolly works fine, under pressure. But being on the suction end of the pump, it >can< (and prolly does) suck air in, past it's seal.
Yes, the Fuel Pump is under the Driver Side, on the inside of the frame rail.
You can buy a specail tool to remove the QD fitting OR, if you look at it long enough yul see a "clip" that can be pulled out with a pair of neddle nose pliers. you can then pull the fitting assembly off.
Buy a foot of 5/16 0r 3/8 Diesel friendly fuel line, pre-measure the length yul need, remove the fitting & it's attached OEM line assembly, replace it with the Fuel line and band clamps..... done deal. 15 minute fix.
I'll bet you notice the Dif ;) :D ( a bit quieter idle noise, smoother idle too)
JOE
Watch for dribble'n fuel... Just be Quik about the swap
jguzman75
McAllen, Texas
Mission,Texas
Well during lunch it did it again, when I left work it worked fine but when I started it after lunch to come back to work as soon as I started it up I noticed a slight rough idle so I turned it off. I turned the key off and on a few time pressurizing the system and turned it on and it ran perfect so I really think that you are on to something. Thanks.
Sounds like Air in the Fuel to me. But because of the GP incident you had, the GPR system(s) needs to be checked out too.
JOE
Milly333
