Here's How to add a Custom Signature to your posts
1. Select the "User CP" button at the top left of the Menu Bar.
2. Select the "Edit Signature" button at the top of the "Settings & Options" bar on the Control Panel on the left side of the page.
3. Type your Signature information/details in the text box(Truck year,Model,4x4 or 4x2,any modifications made,etc)
4. Click the "Preview Signature" button to view signature as it will appear when you post. Make any changes or corrections necessary to get it the way you would like it to look.
5. Click "Save Signature" when you are finished. It should now appear on your posts here at SuperDutyDiesel.:sweet
RoyBoy
Diesel Dork
central WI
I want to put an image in my signature, and for some reason every time i try to upload the pic, I get an "unable to save image" message. I am sure my image was small enough and still no go. What's up with that :confused:
Whats the dimensions and file size you're trying to upload Roy?
Limit is 67x100 at 20kb
Hmmm I'm going to pass this up to Tier 2 support:sweet
Roy check it out now as Kevin made the fix:thanks :cool:
You ought to be able to put a little bigger pic in that sig Roy (and maybe a few less lines of text), the pic size limit is 500x100 which is about what the size of my sig pic is.
:hahaYours is smaller than your avatar....:haha
RoyBoy
Diesel Dork
central WI
well Mikey, I think it's somethin with your software because I just loaded the pic as a 4 + Mb file (as well as some smaller sizes) and it still shows up the same size :rant
I bet you got the privilege of a bigger picture than us regular members or something :dunno
BTW: it says max size is 100 X 67 or 19.5 kb
