HEY BAMA!!
94f450sd
certified nutjob
plymouth,ma
i think im about to melt something in the car carrier with the CB.when i deadkey the mike my tach drops to 500RPM.while talking the tach bounces all over the place. :eek: :eek: :D im running a magnum S3 with a 1.5 watt deadkey into a texas star DX350
jharvey
Shutter Bug
Georgia
Sounds like your SWR is outta wack, may need to check it using a tone generator plugged into a O-Scope after bypassing the DSP but just before the 300 OHM HI PASS FILTER but be sure to disconnect the 2.5KHZ COLLINS MECH FILTER or you'll burn up your ROOFING FILTER and if that goes then you'll need to replace the 270 HZ CW FILTER and the FILTERED POWER CORD
Oh wait a minute you're an 11 meter guy :eek:
:tounge :tounge :tounge :roflmao :roflmao
:confused: :whah :whah :whah :confused:
teacher!? TEACHER?! could you repeat that, my pencil lead broke?
W4RLR
High Tech Hillbilly
Sewanee, TN
Happiness is an amateur license, and the knowledge to understand everything you just said.
Of course those of us with an amateur license know the true value of your "assessment". :roflmao :D
