HID conversion
97CREWCABPSD
Smoke What Smoke Officer?
Salem, OR
Has any one found any good quality HID converions for the 97 F350s that are reasonably priced.
I havent' seen any that I'd consider decent quality for what I'm willing to pay. Having seen the difference on some trucks w/ diamond cut headlight cups & wiring kits I'm not too ready to jump to HID conversions. Once you upgrade the wiring you can cheat & get non DOT approved higher watt bulbs and you'll have all the blinding light you want.
I'm not advocating putting the higher watt bulbs in there but as a result of the wiring design of these trucks as they age the voltage drop before it gets to the bulbs can be rather significant. Currently all of the power runs through the dash switch by switching to a larger wire and having the current switch trigger relays it will allow you to get the intended voltage to your current light bulbs. This even in stock cups makes a dramatic difference on some trucks you need to actually check the voltage @ the plug for your truck if it's more than 0.5V lower than what's @ the batteries w/ the truck running then you'll see a notable benefit.
Another beneficial upgrade is a brite box so you get both filaments lit up when your bright lights are on.
Big K
SDD.com Hacker/Admin
Dallas, Texas
97CREWCABPSD said:
where did you get the diamond headlights.
There is tons of places that sell them.
procarparts.com
and ebay.com are just to name a few :sweet
