HIDs???????
94f450sd
certified nutjob
plymouth,ma
ok i got a set of HIDs from a friend.what do i need to stuff them into my 94 or 95?i need to change the bulbs i think cuz they came from a foriegn car.the bulbs say 35watt/8000k on the tag.do i need special headlight housings for them or wil my stockers be ok?theres only 2 wires going in and 2 wires going to the bulb.wheres the high or low beam or do i need a different setup?
stroked 350
coventry,ct
Rich , i don't think thay have high beam. If you use them you should look for an upgraded harness. I have seen them melt oem sockets . Chuck
94f450sd
certified nutjob
plymouth,ma
no high beam?how do you get a sticker with them?:dunno as far as the harness is concerned, i can do the relay mod and use 10Ga wire from the battery to the relay and relay to headlight plug.and make a 10Ga ground wire to each plug.
this is what i got the bulbs and connector look like a 9006 bulb.but i would have to imagine i could order at least the ford bulb i need and use the GM looking plug to splice into my harness.
94f450sd
certified nutjob
plymouth,ma
and they were free.dude needs some work on his tractor so i upped the price 100.00 cuz thats what he wanted for the lights.and i was still cheaper than anybody else to do the job. :D
